So my CUCV has a low coolant sensor. The truck has had a hard life and much of the electrical is problematic due to corrosion. Anyway, the sensor light goes on a lot, even though the coolant isn't low (the sensor is nearly half way down the radiator). I was hoping someone on here knew how it worked electrically? I checked it's resistance to ground and it's open (infinite resistance) with full coolant. It would make sense to me that it would be open full and closed when low, so +12V could flow through the dash light when low, but this doesn't appear to be the case, since the light is intermittently turning on...
I shined up the connector on both sides and it seems to have helped, but of course I've done this before. And the sensors itself could also be bad...
Anyway, if I just knew for sure how it was supposed to work, that would be helpful.
