CUCV2
5/4 ton fun
Going closer to the minimum speed on the highway rather than the speed limit has worn out its novelty. After researching it, it seems like the best way to add a gear is the 4L80E. I found a donor tranny that was rebuilt 5K miles ago by Jasper out of a 93 GMC K2500. Issues that I am aware of are:
1- Mods must be made for the computer controls
2- Shifter may have to be modified
3- TC will need to be converted to the passenger side
For issue #1, there is a full manual valve body option by transgo.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=TRG%2D4L80E%2DS&N=700+400214+115&autoview=sku
For issue #2, there is a floor shifter available by Lokar.
http://store.summitracing.com/partd...-ATS64L80R2&N=700+4294822068+115&autoview=sku
For issue #3, Kert at DIY4X.com is the man. He is working on a clocking ring that will work with the current CUCV TC and the NP241 (d-side) adapter to actually clock it over to the p-side and up some. It is not the full clocking like his other rings as I understand it but a happy medium of sorts because there are only so many ways to make this arrangement work. The clocking amount should be ideal for this situation because this truck is a DD and the plan is to keep this tranny swap as simple as possible.
My questions are;
A) Is there anything I am overlooking?
B) Does this plan have merit?
C) Are there other options that may work better?
Thanks in advance.
My questions are;
Thanks in advance.
