Cummins 4BT's
The engine run from $1000-3500 ,also you can buy complete running trucks,but you'll have to drive,buy off ebay,ect.
The cummins uses adapter to mate up the Gm trans ,Th400,465.The adapters can run $500-800.
You'll have to fab up your mounts,the best rubbers isolators are the stock liquid filled and mount to your fabbed up brackests.
Wiring is a piece a cake std alt,battery,starter,power up your fuel shout off.
so a quick run down.
Engine $ 1200-3500
adapter $500-800
fab parts $?
Drive shaft work ?
exhaust work $300.00
I do have engines and adapters so if you need anything let me know!
1-tonmudder said:
My bad I meant CrewCab59.
Yes,
I have adapter,flex plate,spacer,and all the bolts,almost new starter.
$600.00 plus the ship/or come and pick it up.
This Came from Cummins and it was on a test engine,all these parts or low /test hours.
CrewCab59
