For those of you who have swapped in a 6bt, how much sag in the suspention did you get? I'd like to still be able to flex and was wondering what the consensus on 4"lift Tuff country 56's should finish out at run in Kerts B52 brackets up front. It would be 8" of lift before the engine weight. I need to be between 4 and 6" of lift after the drivetrain goes into the frame. Any help is greatly appreciated.
