LOGANSTANFORTH
So, I plan to build my 96 Cummins powered Dodge Ram 2500 into a NMRO mud racer (gave up on the sled puller idea, too much of a hassle) that will also see dirt, sand, and pavement drag racing use.....any of you guys run Class 2 or Class 3 in the NMRO?? cause i would like to see your rear leaf suspension setups, Being that my truck's front is a 4 link from the factory it should be easy to setup, im thinking 3 inch lift 1/2 ton coils to help with the weight transfer, it should set stock but should really plant the rear tires when i drop the hammer on the skinny pedal, I know i will be running a set of 7 foot ladder bars for my traction aid on the rear, i just want too see how you guys set your leaves up (soft or hard), wether you are running bump stops or not and all that type of stuff.....I'm open to ideas......This should be fun once i get the 800-900 ft-lbs of torque on tap......Oh the truck will be ran as light as possible, every piece of steel that isnt needed will be removed......I think i should be able to get the truck down to less than 5500 pounds, i think it weights about 6500 right now......It should be fun......
