79diesel
Registered Member
Just finished putting a 91 non intercooled 6bt into a 79 GMC Sierra. Everything works good except the power steering pump isnt putting out enough for both power steering and hydroboost brakes. It loads up the engine it is working so hard. It barely has enough power for just steering. Could this just be a bad pump or should i look into a different pump setup?
thanks
thanks
