cabledawg said:Hey ryoken, how does the fuel press on the hood work for you? I dont feel like spending $90 for a damn electric setup, but I dont want something that will break off or get damaged by the weather. Does it hold up well?
Awesome.. There was no way I was running an isolator... Obviously cost was a big issue.. I thought I remembered them in the $150 range...
But I knew eventually I wanted to run fuel and vac out on the hood.. So going with the 2 mechanicals was a no-brainer.. Eventually, I'll have fuel and vac mounted to the back, underside lip of a cowl hood..
I just got the short AM braided line setup, it's been flawless... I run the liquid-filled Pro Comp... Rock steady and looks like new...
