DR
What have you done to mount your radiator?
It seems that no matter what I do, I cant keep my radiator in place. My front end seems to flex more than it should. I have replaced the entire core support along with new body bushings, radiator mounts, and new rubbers... And it still moves. It flexes enough that it cracks my core support. This last time I had an issue with it I re welded the cracks in the core support and ran 1/2 square tubbing from the frame to the core support at each side of the radiator trying to stiffen it up. I also recently added windstar fans to the mix. I built a metal frame for the fans that attaches at the top and bottom of the radiator thinking that it might stiffen up a little bit.
This passed weekend I went out playing and the front twisted enough that it made a jagged edge on the front side of the radiator. The radiator then moved enough that it caught the jagged edge and gave me a nice big hole!
So, I am back to square one. I think my next step will be to start from scratch and build a custom support of some type. Im thinking something that mounts the radiator solid with no rubber. Any thoughts? Has anyone else encountered anything like this?
