cut e-brake cables, what to do now?
chevyguy82
topeka, kansas
i just got some axles from an 80 3/4. 10 bolt front and 14 bolt FF rear. i've pulled the drums off and inspected everything. the emergency brake cables have both been cut off about 2 feet out of the drum. can i just use splicers or connectors to connect them to my stock setup from my 10 bolt or do i have to buy new cables? does anyone have pics of the 14 bolt set up with the cables hooked up?
Cut brake cables
I've got a set of drums complete rear with park brake cables.. You can have if you provide the shipping.....
if the 10 bolt cables mount to the drum the same way they do on the 14 bolt, transfer them over.
