Which is the best type of cut off tool to use in a typical K5 floor repair? Soon I will be cutting and replacing part of the floors at the tailgate and behind the front seats. I own a 4 1/2 inch angle grinder, but is there a better tool?
if you have air, just get a straight die grinder and run a cutoff wheel arbor.. way better than "muffler cutters" with the shield...
but if your electric only, it's hard to beat a 4 1/2" grinder with the appropriate wheel.. you can buy straight electric die grinders, and run the aforementioned arbor with good results.. heck, we run the super cheapy Harbor Freight one at work, and tho a POS, it does the job..
here's an arbor for die grinders
What about a sawz-all? I know they make quick work of sheetmetal with a decent blade, will it work better than a cutoff wheel?
4.5" cutoff blade in electric makes short work of most everything though, this I know.![]()
I went to a grinder after seeing my electric bill skyrocket from using an air powered cut off tool,my compressor gobbles killowatts ,but a grinder can run all day and use about as much as light bulb...air tool might work faster,but it'll piss off the neighbors faster too!...and wheels cost more for them than a electric grinder...when I need to chop bolts off or large sections of metal I use my 9" grinder with a circular saw cutoff abrasive wheel on it...
I was getting used 14" chop saw blades from a welder after he wore then down to about 7" and they became useless for his chop saw for free...they are thick but last a long time..I now try to use the grinders before air tools or torches to save money on oxogen refills and electricity..
I had one blow up, 2' from my face....after I figured out wtf had just happened, I looked up at the roof of the shop, 15' above my head...there were giant pieces of that wheel stuck in the cieling.
but even at that, big cutoff setups like that can be hairy, even at appropriate speeds...
, but any kickback or bind can really putting a hurting on ya.. I'm always as careful as I can be, go slow, work gloves, faceshield, etc.. even than I make myself nervous...
..I dont even like working under my vehicles now,not only due to my aching back,but the peices of rotted body metal dropping in my eyes can be very hazardous--safety goggles or face sheilds dont always keep them out of your eyes no matter how good they fit...Die grinders require a seriously beefcake air compressor to use as efficiently as a 4/4.5" grinder. The little 110v craftsman, roll around compressors will get you about 20 seconds of use before the compressor kicks back on.
mechanics use a 4 1/2 grinder.. body guys use die grinders and arbors... that's my observation...
