I have a miter saw that I was given. It has a cutoff blade on it which obviously works well for small metal cuts. Can I use that to cut 4x4 lumber or should I go get a traditional blade for that duty? I'm wondering if the cutoff blade can handle the thickness of the cut safely. I just want to do a few cuts, but I can certainly spring for a "regular" blade if it's not safe to use the cutoff.
