I understand the "how to's" and "why's" of cutting brakes but I'm curious...
Can you use them with a rear axle spool? Will both tires being 100% locked together defeat the purpose of the cutting brakes?
If they are still worth it, which lever assy is best - single lever (activating both together) or a dual lever (independantly activated)? It seems like it wouldn't matter since both tires will lock up so either the cheaper of the 2 or the dual lever if they're the same price.
