chevysmithz71
I put this HP Solid Axle industries axle in and I just don't feel it is using its full potential of the High pinion. I have 6* caster right now so the knuckles look good for steering but the pinion I know wants to go up. Plus, I still had to use dang shims after a welded new perches on(not happy). These pics look like its still low pinion, I ground down the pinion nut to help not hit my ujoints.
How have you guys done this? Being pressed on it seems like it would be pretty tough. Maybe cut the welds and leave under truck and use a Jack at the yoke area to jack it in place?
I bought it used and was supposedly under a K5 but I really am getting tired of changing things around and Just want to do it right.
Thoughts????
Thoughts????
