blazeonchevy
Never heard it was possible. Well I found the part to do it. The guys at a local driveshaft shop have a yoke that bolts to the transfercase and allows you to run sort of an open ended CV shaft.
It is an expensive part though. They want 85$ just for the yoke.
Is it worth it though.. I cant seem to find an np208 for a 350 tranny, and from what I can see an Np205 would have to have a different yoke as well. Not sure though, may be wrong on that one.
So basically every case has its downside. The first two have the added difficulty of putting a completely different case in, and the 203 is still fulltime. But want to stick with the 203 if it seems like a decent solution. Mainly because I dont have to go out and buy a case that would still most likely need to be rebuilt and have the parts I want put on.
So My end goal is to have a Rebuilt case, part time, with a cv rear drive shaft.
What do you guys think would be the best route as far as cost, and least trouble?
