That is proper.
I had read some where they need to be phased 90* from each other. Then I started looking and noticed mine are all the same direction. The rear is just SLIGHTLY off of perfectly lined up with the CV side.
That is proper.
The pinion nut could be loose or pinion bearing bad. You haven't had the yoke off, have you? What was the last setup where it ran without vibrations?
Man, my setup is identical to yours except I have 6" shackles.
My rear shaft couldn't even be balanced by the guy that cut it down. But I went 70+ on the way to the dunes and have zero vibration...
could you maybe measure your angles and post them up? I'm pretty much grasping at straws at this point.I'm going to have to bet a u joint installed funky, or the tail shaft bushing.
On the tail shaft, there is the seal, but behind the seal, there is a brass bushing that supportstthe yolk.
Really? All I've seen is a bearing in my208 tail shaft. No bushing
So driveshaft is fixed and profesionally balanced.
Check tires for balance, check wheel bearings. Check pinion bearings. I have learned just cause it didn't have it before doesn't mean something really weird didn't happen
It certainly doesn't feel like a tire vibration. I guess I can take it up to discount and have them balance the tires.
Bearings are good. I was planing on spinning the pinion and feeling it when I got off work tonight.
Is the bushing replaceable with just pulling off the seal or do I need to bring the whole housing down to get it pressed in?
