I'm at my wit's end with this problem.
My truck is a 1991 K5 with a carbed ZZ4 350 swap.
It uses an MSD6A ignition and a super billet distributor without vacuum advance. MSD 8.5 wires, and the Champion plugs specified for the ZZ4 (can't remember the part# off the top of my head...).
Motor generally runs amazingly, except for one issue; no matter what I do, my #5 cylinder wire will eventually start arcing out on the header. Here's what I've done thus far:
-Moved battery ground off point on AC accessory bracket to frame (PO rigged this setup
-Added a zero gauge ground wire from the fuel pump block off plate to the frame (truck has electric pumps, this was the most available/easy spot for grounding)
-Tried both 90* and multi-directional plug boots
-Tried using high temp boot sleeve (arcs through the sleeve!)
-Added zero gauge ground wire off passenger cylinder head to frame
-Swapped 8.5 to 8 mm plug wire
-Swapped plugs
This is most problematic upon acceleration and during idle; wire will arc and make a very distinctive "pop", engine sounds like it chokes out, then comes back, which clearly must be hard on the motor. It happens more frequently when the motor is hot, which makes sense. Could this also be a something triggered by the lack of a vacuum advance, since it seems to be most prevalent when accelerating/idling?
I called MSD and Summit's tech lines, and both agreed the issue was ground related; MSD sent me a new plug wire with a high temp boot that was promptly destroyed after 3 miles driving. Even after having added two separate ground wires off both cast iron and the offending aluminum cylinder head (I know aluminum is a weak conductor, but it was a last ditch attempt at grounding the head directly), the problem persists.
Any suggestions?
)-Added a zero gauge ground wire from the fuel pump block off plate to the frame (truck has electric pumps, this was the most available/easy spot for grounding)
-Swapped plugs
Any suggestions?
just cause I just saw this smiley.
