d 60 conversion
big_bad_blazer
yankton, SD
ok after i get my tranny and t-case rebult i am going to start on my d60 conversion. i was just wandering if you have done this do i need new drive shafts u joins and spring or is it just slap the axles on. i have a 203 t case if that helps. i was just wondering so i get all the parts befor i do it. that is the easyest way. waiin for parts makes me mad. thanks fora ny help
I just did this... contact stephen at ORD, our site moderator... he had everything to make it a bolt in and had lots of good ideas... and I didnt have to shop around..
took about an hour to do... 45 minutes to show the wife which tool and 15 to actually do it (I do however have a well equipped shop/lift/jacks/ air) so if you are backyarding it you and a couple of buddies and 2 hours
