D-ring shackle to reciever hitch?
Ben B. said:
What all would I need to mount a D ring to a reciever hitch?
A piece of 2" square tube or solid stock, a drill press, and patience.
Mine ended up being a piece of 1.5x2 stock, as the CUCV and (in this case) deuce and a half shackles are 1.5" inside. I then welded 1/4" stock to each side to make it 2" thick to fit in the receiver ... think I used .25 x 1.75" or so to give me lots of welding room.
http://www.slosh.com/ck5/hitch-shackle-1.JPG
http://www.slosh.com/ck5/hitch-shackle-4.JPG
http://www.slosh.com/ck5/hitch-shackle-6.JPG
http://www.slosh.com/ck5/hitch-shackle-7.JPG
5/8" holes for the hitch pin, at various spots to fit in my various trucks, and then a bloody great hole on the end for the shackle.
I did even paint it and stuff, donno why I can't find pix of it. Came it handy dragging the pickup around when the motor seized :doah:
I also keep meaning to drill another hitch pin hole at 90 degrees to the others, so that I can use it with the shackle moving left-to-right as well as up-and-down.
Or yeah, you can buy them ... but I had all this stuff sitting around in my garage, including the aircraft cable leftover from my parking brake cable project. :eek:
-- A
I made one for my Father. I used solid 2X2 and welded a d-ring (with pivot) on it. Never broke, we pulled a fully loaded 1 1/4 ton dump & 2 1/2 ton chipper out of mud with it! Pulled many a tree over too. I also took another 2x2 solid chunck and milled the end down to use a shackle on it. But they lost the shackle, then the 2x2 stock.:haha:
The Warn setup looks quick and easy. I'm not much of a fabricator.
What do you guys think about for the front, removing some of the bumper connected to the frame rails and welding tabs and mounting D rings on there?
Many have done that as well. I've also read to bolt it to the frame not weld. Can't remember why.:o
Dam Dremu how much that thing weigh? I'm guessing it would hurt if it fell on your foot!!!:D
Nah, you just learn to dance and let it chunk the concrete :haha:
I'm sure tube would have been perfectly good, but I happened to have some of that solid stock handy.
-- A
