D-shaft, shifter cable, trans gauge, carbs, radiator...
Avery4jc
1 ton status
Fresno, Ca.
I've got some small stuff sitting around so I'll list it all here. It's all located in Fresno, Ca.
5 foot shifter cable that came with my Art Carr/Winters shifter. It was too short and I never used it.
$50obo
AutoMeter Transmission gauge. Comes with sending unit. Pulled it out when I re-did my gauge cluster with a full set of gauges. Measures 2" on the body but I think it's technically a 2 1/16" series.
$30obo SOLD!
Quadrajet off a mid 70's small block according to the numbers. Needs a rebuild but it's all there.
$30obo
Holley 600 carb with the bracket to hook up the TV cable with the proper geometry for a 700r4 transmission. Ran when I pulled it to put fuel injection on.
$50 obo
Small block radiator. It's about 5 years old. I pulled it to put one in out of a big block truck. It's dirty but worked fine. Transmission cooler lines are clear and working too.
$40 obo
Front CV drive shaft. NP208 flange. Came out of my truck when I had a 10 bolt front. I replaced the u-joint at the axle yoke and it's good to go.
$50 obo SOLD!
Is the radiator for a 73 - 80 pickup? If so, how much to ship it to zip 97801?
Let me know.
Thanks.
Let me know.
Thanks.
It was in an 85.
willing to ship the front driveshaft? quote to 12019.
I need to work up a quote on something else so I'll figure them both out tonight after work. I shipped a rear driveshaft across the country this past summer and it wasnt horribly expensive.
did the truck that driveshaft came off of have any lift?
Yeah at one point it had a spacer with an 8" lift then when I went down to around 5" I ran it as is. But to answer your implied question it's stock length.
If wage isnt interested in the d-shaft I am. My zip is 71655. Do you take paypal?
