D44 & 10 Bolt front brake line help.......
Beast388
Clinton, IA USA
I need to replace my stock front brake lines with something longer. I want to use the extended Napa (or other) lines that have been listed numerous times here on CK5.
I know that the D44 uses a 7/16" (0.438) banjo and the 10 bolt uses a 10mm (0.394) banjo. From what I understand the extended 10b lines can be drilled for the D44 banjo, but there will need to be some modification to the mounting area of the line, caliper or both.
If anyone has pics of a 10b caliper with the line running to it, post them up so I can see how much modifying needs to be done so I can use extended 10b lines on my D44 calipers.
I have considered just switching to 10b calipers, but I have already clearenced my current ones for my wheels. /forums/images/graemlins/doah.gif
I want to explore this cheapy option before I shell out $80-100 for extended stainless lines. /forums/images/graemlins/yikes.gif
Thanks in advance for the help. /forums/images/graemlins/bow.gif /forums/images/graemlins/waytogo.gif
As you can see, I've got D44 calipers with the Napa lines. I had to drill out the center hole for the 7/16" bolt, and I also had to shorten the bolt a little as the hose end(big square brass end)is thinner on the 10b lines than the 7/16" bolt(so in other words, you'll bottom out the bolt before the bolt hits the square brass hose end). Does this help any?
Sweet!....thanks Jeff! /forums/images/graemlins/waytogo.gif /forums/images/graemlins/bow.gif
So the end on the 10b line is square like the D44.....but without the ears that engage the caliper?
Heck, If I have to ream a hole and shorten a bolt to make this work....piece o'cake. /forums/images/graemlins/waytogo.gif
Anybody else done this mod? /forums/images/graemlins/peace.gif
[ QUOTE ]
[/ QUOTE ]
That is a big 10-4 /forums/images/graemlins/waytogo.gif
Another question....what type of frame-end do the Napa lines have. Is it the threaded end or the clip-type end? /forums/images/graemlins/thinking.gif /forums/images/graemlins/dunno.gif
It threads into the hard line like normal, then i just took my dremel to the inside of the stock "U" clip to make it a tad bigger. I can get a pic of that also if you'd like /forums/images/graemlins/grin.gif
[ QUOTE ]
[/ QUOTE ]
I guess I should have clarified /forums/images/graemlins/histerical.gif.......I need to know how they mount to the frame. Mine have a threaded nut, and I know some later rigs had the clip type end. /forums/images/graemlins/thinking.gif
So, it sounds like the Napa lines are the clip type? A picture would help alot....thanks Jeff! /forums/images/graemlins/bow.gif /forums/images/graemlins/waytogo.gif
It actually fits thru the hole in the framerail to screw into the hard line on the otherside....then as you can see, i just slightly ground out that clip to hold it in place /forums/images/graemlins/waytogo.gif
