carpeonnel
Are d44 axle shaft joints 1330 or 1310? Anybody know off hand
Hossbaby
I have never replace axle ujoints but by what you said about tack welding the caps in place: Do the axle shaft "ears/yolks" not have little tabs to keep the caps on like the pinion yolks have on my 12bolt? Now I gotta check my D44 axle joints to see what they look like.
On a side note. Who else sells high grade replacement axle shafts for 44 other than ORD
HossBaby)
.As for good ujoints if you want a good ujoint you can drive on the street look at CTM's and possibly Yukon Superjoints. I know Longfield doesnt recommend his joints for street use but they are great joints too if you don't street drive the truck much.
).yeah i've been looking at chromoloys, Warns, and the CTM joints. It seems no matter what, I'm looking at basically a 1K for that axle and strength upgrade. And people are probably trying to type now saying just save up for a 60 and sell the 44, but no thanks. I don't know how people can find 60s for the $200 and other crazy good deals they find but I congratulate you. I just think of it like this: I can spend another grand and buy upgraded axleshafts, u-joints, and pinion yoke (HossBaby)
or invest in a 60 and have a price breakdown like this (at least in my mind):
Junkyard D60 - $650
Misc rebuild parts - $400
Prob. need Panhard bar - $350
Steer arms - $100
Possible M/C change cuz bigger D60 brakes - $100
CTM's use bushings and are not recommended for street use. Alloy USA offers a joint made from 8620 steel with lifetime warranty for $35 or so (D44/10 bolt stuff only, they don't make a joint for the D60 yet).
Well unless you're running a 203 you're not gonna be running it on the street in 4wd, right?
You'd be VERY lucky to find a D60 for $650.
As for rebuild costs, I had to invest very little in mine. I suppose that depends on which front D60 you might find (and hence how much its worth). $400 for rebuild parts sounds steep to me.
I don't know why you think you'd need a panhard bar with a D60 and why you think it would cost $350
If you plan on crossover steering, the steering arm is a set cost for either axle. If you're not using crossover, you don't need to buy a steering arm.
The master cylinder change is unnecessary IMO.
I'm not necessarily suggesting that you get a 60 instead of dropping $1000+ into your D44 but a lot of your proposed D60 costs are not too justified.
