handloader90
Building!
I can't find the location of the breather on my Dana 44.
I found a hole roughly 1/8 in diameter on the topside of the pumpkin behind the diff cover on on the drivers side, the hole isn't tapped. I was certain this was it, but I cleaned it off real good and looked down inside with a flashlight, it only goes down about a centimeter and bottoms out. I put some fluid in there to see if it would escape down into the diff and it just sat there.
No fittings anywhere and I've looked this thing over about 5 times in the last two hours. I did a little research and found that some D44's have the diff breather on the tube, but that's for the rear D44's.
Any advice?
Here's a photo of the hole that I'm referring to:
Any advice?
