D44/D60 yoke
MTBLAZER89
3/4 ton status
Kalispell, MT
I know they are both 1310. Are they the same?
I chipped mine last trip out where the U-bolts go through. I blew a cap and it bent the U-bolt which in turn chipped the yoke. Straightened them, but it happened again and I expect it will continue to do it.
Not ready to build my new 1410 shaft, but wanna do a couple more trips this summer too.
You used the yoke off of a 10b? I think I may have one, but would rather use the U-bolt dana style than the straps.
The splined section of the pinion on a 60 is way bigger than a 10 bolt/44. The ujoint is the same (1310), but the yoke and pinions are totally different.
:doah: I misread.... I could have sworn you were asking about the ujoint instead. My bad. As stated, different yokes for the same ujoint.
