d44 flat tops/steering arm
big dan
Arkansas
I have a set of flat top knuckles with the passenger side being milled and drilled for crossover. Its got factory studs holding a wfo tall steering arm. Steering arm is a dinged up a little from removing tie rods, driver side studs will need to be replaced if you ever go to hi-steer, comes with brand new moog ball joints that have been installed and driven around in my yard but never gone down the highway. One of the grease zerks stripped the threads so I tightened it down and put a small tack weld to hold it in but it works fine.
Parts are all installed on a working vehicle and will be until I get my replacement parts bought but if someone wants them it will only take a couple hours for me to pull them.
Needing to get $300 plus the shipping, the ball joints alone cost $200 from oreillys. I usually cant get out to mail stuff till weekends but will do my best to get the parts out asap.
How about $200 without the balljoints? Going to be pulling them off this weekend.
Last price drop $175, no ball joints have them off and ready to ship. If they don't sell by Monday they go on ebay.
Tried to get the hammer marks as best as I could to show you what I was talking about. Got pretty wild when they wouldn't come off after days of soaking in pb blaster. Studs on passenger side are damaged but shouldn't be a problem unless you need to remove the arm in which case be prepared to replace them. Other marks are just cosmetic, could probably smooth them out with a flapper wheel if they bother you.
The passenger side arm won't need to come off to get a ball joint in there? You do $150 plus shipping?
Ive had this set of knuckles and steering arm on 3 different vehicles and changed ball joints each time it changed vehicles, never removed the arm from the day I put it on. Always used a ball joint tool from oreillys, its a little tricky to line everything up and work the tool by yourself but it can be done without removing the arm:waytogo:
I can do $150 plus the shipping. Send me a zip code and Ill get you a shipping price.
Sounds good, I'll take them. Shipping will be to Auburn, MI 48611. PM me once you get an idea of price and how you would like to be paid.
I know the factory arm needed to be removed to do ball joints, wasn't sure about aftermarket ones.
