lochenjons
I've been looking into what I need to go to a x over setup on my 77 k5 cause I'm sick of not being able to turn or only being able to turn right, etc. From the look of it, the drivers side knuckle is flattop and the pass. side is not. Most of the pics I've seen showing flattops are the pass. side. Is this the side that matters or do they both have to be a flattop? I assume only the pass. side would have to be a flattop unless running high steer right? Why would only the driver side be flattop on my 77 then? I can take some pics if you guys want too. I know a guy who has a rolled 74 k5 that hes gonna scrap so Ill check to see if it has what I want, if what I have isnt gonna work as I assume it wont. Also I assume swithing output shafts on my current steering box is more work than simply putting a 2wd one on correct? Or is it gonna be a pain to get all the fittings to work right with the 2wd box so I might as well just switch ouputs?
EDIT: After looking some more at the x over kit from ORD I notice they have pitman arms too, wont the stock pitman arm from a 2wd box work?
EDIT2: And are there other places to get/alternatives to ORD steering arm? I'm doing this on a VERY low budget and $150 for the steering arm pretty much would take up the whole budget
. I could weld it but would rather not go through the work. Hmm... I'll look around the pick n pull this weekend and start collecting some parts, and look for a draglink that might work. Anyone know the length it has to be with a 4" lift? And I assume its the same length with a 52" spring swap, since I'll be doing that too soon?
