GsxrMike
Hey there. I bought a 86 blazer with a 14ff rear and 10 bolt front axle. The 10 bolt has 8 lug hubs on it and the guy gave me a D44 that is disassembled with the blazer. I think he put the D44 hubs on the 10 bolt but not the knuckles. The passenger knuckle that came with the disassembled D44 has been milled and drilled for a crossover steering set up but it didn't come with a tie rod. I would like to switch the knuckles so I can put on the crossover steering set up but don't know if I can reuse the tie rod from the 10 bolt. If so does it go above or below the "arms" on the knuckle. Thanks!
