I just put new bearings on my d44 carrier and pinion (replaced timken with timken). If I installed the shims the exact same way, how likely is it that the gear pattern will be good? I am having a hard time applying a 40 ft/lb load for the pinion to get a proper read. Any tips on how to do this if my axle is sitting on jackstands in my garage? It is currently assembled hub to hub.
Should I run it?
