D44 Parts (8 lug, hysteer, 1350,..)
Hossbaby50
3/4 ton status
Peoria, AZ
I have a few D44 parts I need to get rid of.
#1: Complete Hysteer setup. (knuckles, arms, tierod, draglink, pitman arm)
#2: Complete external 8 lug setup w/ Warn Prems, & near new discs. (spindle, backing plates, hubs/rotor, bearings, locking hubs)
#3: 1350 Strap style yoke.
#4: stock 1310 ubolt yoke.
If your interested let me know and I will shoot you a price and details on whatever your interested in. Shipping is on you from 85345.
Harley
Brand and pics of the highsteer would be nice.
I believe the hysteer arms are custom. The PO had access to a machine shop so I believe he built them. They are flat non-taper arms made from 3/4" plate. The system is setup with heim joints on the tierod & draglink which are included. The system does use spacers under the arms so that the tierod clears the axlehousing. The tierod and draglink are .250 wall 1.5" DOM tube. The draglink is straight not bent. The knuckles are already drilled and tapped as this was on a running truck. I will get closer pics sometime today but here is a pic of the system still on the PO's truck. The only known problems with the hysteer setup is there is at least 1 bad balljoint I know of (drivers upper) and one bolt is seized/crossthreaded on the tierod.
displayimage.php
The 8 lug is an external style 8lug with warn premium hubs and almost new disc's. Everything seems to be in good shape except there is 1 bad wheel stud & 1 bad spindle bearing.
Prices:
Hysteer = $400
8 lug = $200
Harley
Damn, I'm out. I need tapered for TRE'S.
If you are trying to do lowsteer the knuckles lower holes are still standard taper for TRE's. This kit is complete though with all the heims, and I just for got the pic of the pitman arm since it is still on the steering box.
Harley
Hysteer still available. Arms, tierod, draglink, pitman arm = $275
1350 yoke still available. $50 shipped.
Knuckles and 8 lug pending sale.
Cover pending sale.
chromo's pending.
Harley
Everything is sold except for the 1350 yoke, 1310 yoke, and the housing.
1310 = $10
1350 = $40
Housing = free
Harley
