d44 swap----brakes
WJACKSON11X
Madison,GA
Alright guys, here's my question. Im doing a 3/4 ton swap this weekend into my ride. getting rid of my 10bolts. Im finishing up the d44 front axle.All I have left is to buy new calipers. What calipers do I need to buy to reuse my new stainless brake lines? I was told that the fitings are different on the two axles. I have the lines installed now on my 10b.
Why don't you use the calipers that are on your current 10 bolt? They will bolt right up to your D44 and you don't have to remove the lines.
thats what i was thinkin....you don't even have to break the brakeline loose on your 10b and they'll bolt right up to 44 brackets and you won't have to bleed the fronts!
Thats the answer I was looking for. I wasnt sure if the calipers were the same. That's why I love this place, thanks guys. I just installed new brake pads on the front about a month ago, even better.
