D60/14B 4.56 detroit 4Link setup
muddybuddy
1 ton status
Northern, VA
ive got 60/14b combo out of my k30 that im going to part out. with gas prices on the rise, i cant keep both rigs, so ive got to get rid of one of them.
D60 SRW 4.56 gears with new bearings and seals. its been sanded and painted and has stock lock outs and non-neck down shafts. ive also got a sky hi-steer cross-over steering arm and bent draglink to go with it. just needs a tie-rod and ends for the draglink and its ready to go. the perches have been drilled, so they can be in stock location or move the axle 1" forward. i will also throw in a 2WD steering box for cross-over steering. i believe the box has been rebuilt, but never used.
14b 4.56 gears with detroit locker. the hubs have new bearings and seals as well, and its also got disc conversion on it with new rotors (has been sitting, may need to be turned) and the E-Brake Caddy Calipers with new pads. the axle also has a 4link truss on it and all the tabs on it for 4link. it also has coil buckets to run bronco coils. its also got a 1410 yoke on it.
pics attached are of the 14b, i look to see if ive got any pics of the d60. the pics are from when the 4link was being put together. the 14b is also sanded and painted.
looking to get $2,000 obo for the combo with the pitman arm and steering box. pick-up or may be able to arrange delivery/meet for gas money. located at 22039
the 14b is pending, so ill sell the d60 for $1400 with all the cross-over steering/hydro-assist stuff, or $1200 with no steering
