D60 and 14bolt questions
firemedicsafd
Professional Murphy magnet
St Augustine, Florida
Do the stage 8 spindle nuts for the D60 work for the 14 bolt? Do the wheel studs for the D60 also work for the 14 bolt if doing a disc brake swap? Thanks in advance!
The threads are the same but the Dana 60 spindle nuts are a bigger OD than the 14 bolt ones because the 14 bolt hub doesn't have as much room inside. So they don't fit, but the 14 bolt spindle nut system is actually pretty good to begin with.
Dana 60 and 14 bolt wheel studs are different and do not interchange.
