Went out wheelin yesterday and had god awful racket coming from the passenger side. The axle shaft u joint was hot. Tore it all down today and found spindle bearing came apart. Question is with the wear that’s on the outer stub shaft do you think it’s still safe to run it or just get another. I’m running still stock 30 spline outers.
It’s hard to tell but you can see a step in the diameter of the shaft. I tore apart the other side to get a reference and it’s all one diameter hence, why I’m asking .
