Just as the title says, what is the axle tube diameter on a front D60? I would rather not go outside in the cold rainy weather to measure if I can avoid it. My front shock mount has broke AGAIN and this time the broken piece and the bolt are gone so there is no welding it back together this time so I have to make a new mount hence the reason for needing to know the axle tube diameter.
