D60 caliper noise.
jekquistk5
Weld nekid
Pinckney, MI
Let me start by saying the slides are in with the bolts and the brakes are working fine, they just clink and rattle. Last time I had them out I had to pound the slides in so I know they are I there good and the bolts are tight. Both calipers rattle like 1/8-1/4” making them loud when braking. I’ll try and get a video.
Both calipers are remains.
there is a spec on caliper to bracket gap or they can do this .
here is a paper i got years ago with a set of calipers for this bendix style brake . it shows how to check gap and what oversize shim to order .
also make sure you have the spring tab / squeaker on the inner pad or it can chunk up/down on the brake bracket in its slots and make noise .1 of these pad inner pad . the pic just shows more than the pair is all .
that video shows exactly what the pics i posted up talk about .
the calipers are to worn down or the brake bracket is to worn . this is why you need to check the gap and will probably need a oversize wedge for the bottom to push the caliper up were it needs to be .
Looks like I’ll have to measure. Like I said been running these for years no issues just noticing little things that aren’t quite right now that I’m driving it way more.
i got lucky and got this paper in a napa box doing a brake job for a guys p-30 step van box truck years ago . he was complaining of the same think clunk / clunk with the brakes . if you look at the 1st pic you will see my notes and the 2 wedges i had to use to take up his play .
