D60 Crossover Arms
Teamstatic2001
Muskegon, MI
Has anyone else seen those arms the eliminate the king pin spring to get rid of DW. If so had any exprience with em and are they worth it.
I've heard they aren't the most desirable for a DD. Regular arms rely on the spring to keep the tension on the teflon sleeve. I would assume that you would have to shim them every once in awhile to take up the "slack" in the absence of the srping.
The frequency of shimming would depend on how much you drive/wheel it to keep that tension.
Anyone else's thoughts?
I put a double arm on the pass side after rebuilding it and rebuilt the drivers side but used the spring and I have death wobble. I put a stabilizer on it which helped a little but it's getting hydro if changing tie rod ends doesn't fix it. I only do about 3000 miles a year so I am not too worried about it.
Death wobble is generally caused by something in the steering system being loose. Occassionally, it is blamed on large tires being too much for the stock kingping spring preload and some people put thin washers under the kingpin caps to increase the spring pressure.
My opinion? Throw hydro assist on it (you probably need it anyway) and forget about it.
