D60 crossover kit
patt107
north carolina/new york
What size lift is your Dana 60 crossover steering kit built for? Im running 6inch springs ,an extended shackle(1.5 inches) and a zero rate.
thanks
pat
there kits are built to your specs. just tell them what you have and thay will get you hooked up.
best bet is call them as thay are super bissy.
i have 2 of there kits and love them.
So do you think ill be able to give them the specs on my truck(basicly everything i listed above) and they will be able to build the kit for me? My problem is that i cannot take any measurements because im deployed to iraq right now. I am trying to order everything now so its ready for when i get home.
thanks
pat
I think I heard the crossover requires at least a 4" lift so I'd bet your safe. It might be good to call them though if you can. I've got it on my D44 and it's looking cool (still putting it together) Be safe.
greyhoundjc said:
What kind of turnaround time did it take?
mine took awhile since they didn't have the tie rod ends in stock. then they sent me to RH tie rod ends LOL.... so I had them send me the right one. so it took almost 3 weeks to get the stuff. which is ok I guess, I've only installed the steering arm so far.
