D60 Crossover + Zero Rate Forward
BBlazerSK5
Cheshire,Connecticut and Rochester,NY
/forums/images/graemlins/1zhelp.gifHey guys, well i am just pulling my rig in after winter, to put on my ORD crossover steering and highsteer arms. Thing is, i want to put my Zero-Rate Add-a-leaf up front and push the axle forward 1.5" to extend the wheel base just a little bit, at the same time clearing the fenders a little more. It has 6" TCI front spring and the HD Extended ORD greasable shackles, with the crossover steering and highsteer arms, how much can I move the axle forward before I run into contact problems, or any other forseable issues that I missed.
Thanks /forums/images/graemlins/dunno.gif
By the way heres what i have and will be installing by mid-May:
1989 K5 Blazer
Rebuilding 350 TBI
Comp Cam #114102 (500-3500 RPM)
Headman Headers
Flex-a-Lite #295 Electric fan
Dana 60
ORD Crossover Steering
ORD High-steer Arms
ORD Greasable Extended Shackles
Detroit Electrac
Genuin Gear 5.13's
4WD Factory 35 Spline Kit w/ Warn Premium Hubs
6" Tuff Country Springs w/ ORD greasable bushings
1" Zero-Rate Add-a-Leaf
High Angle Driveline 241 Slip Yoke Eliminator Kit
AZ-Kickin Disc Brake conversion for 14B FF
Precision Gear 5.13's
Detroit Locker
BushWacker Cut-Out Fender Flairs
4" Rear TCI Springs
4" ORD Shackle Flip w/ ORD greasable bushings
Steel Braided brakelines all around
Greasable Everything
ORD Weld on Steering Brace
ORD Bolt on Steering Brace
Ranch 9000X's (RS99012)
38.5x15x16.5 Super Swamper TSL's
New Chevy Silverado Charcoal Grey Paint Job
I don't Think i missed anything, This has been my project for the past two years since i was 16, now for my senior year i finally get to wrap it up, and i think it will be one of the sickest Blazers out there. /forums/images/graemlins/peace.gif /forums/images/graemlins/k5.gif
my truck is not the same as yors, but i run 6" skyjacker springs, a 1" 0 rate moving axle foward 1.5" and ord crossover with the d60, and i have no problems at all.
The problem you run into with the crossover highsteer is that the pitman arm can get into the tie rod, so I'm not even sure you'll be able to run the axle offset 1". The 7" of lift might get it high enough to work, but I think the 1" will be the max, if you can move it forward at all.
I thought I had a pretty cool K5 for a highschooler and all I had was a stompy 383 in a 3" lifted '82 K5, you really do have a cool K5!
