D60 Driver side perch. Pin hole is wallowed out
MTBLAZER89
3/4 ton status
Kalispell, MT
What are my options to fix this? It's slightly wallowed left and right, but not too bad. Just want to make it round again.
Actually, i think they came like that. My D60 is like that and i've seen several others and they were all EXACTLY the same. I don't like it myself and i'm thinking about making a new perch and welding it in place of the factory one.
I know I could buy a new perch. I was thinking of welding it up around the edge, and then redrilling it? It's not bad, but with the 52's and long shackles my lateral movement is already enough I just want everything tight.
I have drilled the perch holes out round. Built the spring bolt pin head up with weld & ground it back down to fit the new perch hole. Prolly not the best way, but I was broke & it got me back in the road.
Id have to agree. Seen several that were slightly ob-long. Just pulled one a week ago, same deal.
factory slotted a bit. i have seen atleast 6-8 dana 60's i have owned and all like this. no problems with use at all for me.
Ive always pulled the spring to the outer edge of the hole. My truck leans a bit to the D/S, I wonder if makes a difference going to the inside of the hole.
