d60 front weight? 10 bolt front weight?
ducttape114
Orcutt Ca
this doesnt seem like it should be that hard to find. but i have had no luck.
what does a stock D60 front weight when it is ready to run? brakes complete, cover on, fluid toped off, tie rod in place.
what does a stock 10 bolt or 44 weight in the same condition?
Edit correction. From the shipping weights thread.
D60F~550
10B (8-lug)~415
thank you sir. i didnt even think to look there. 135 lbs dosnt seem like that big a deal to me.
Dont forget those are dry weights. Things like steering arms, dom steering, lockers, bigger shafts, and better diff covers all add more weight AND each piece will add significantly more weight to the d60 than the 10bolt.
Pff and lots not even get into the increased weight from being able to run bigger tires with a d60.
