D60 Full Float Rear Axle Flanges!
Gravel Maker
Sacramento, CA
Something new for us at Ruffstuff! I tried to buy these from another vender but he wanted more than what I am willing to sell these for so we had to make them ourselves and improve them along the way ;)
These are unique in that they will both work for Chevy or Ford D60 front spindles. The Ford will have a small spacer but that isn't ready yet. They are also made to clear the biggest of calipers.
So far we only make these with a 3.5" opening but the 3.25" are on the way!
The way we made them less expensive is all in the machinists' methods and these were made for us by Kyle at NWF. Kyle has a pretty good idea of the best ways to do things. The end result is what counts but the way you get there is what you end up paying for.
With these you can easily use a 35 spline shaft on the rear using common D60 front axle parts. I see these as a great way to use a 9", Sixty9, Solid14, or Torq rear third member and minimize your spare parts needs by using what you already use on the front axle.
These are made from 44W 1" Plate and machined for a press fit. They are $160 a pair for as long as we can afford it but we have 40 pair on the shelf as of today :)
http://www.ruffstuffspecialties.com/catalog/FLANGE60.html
:whistle: ultimate brake upgrade on rear axle via using dana 60 masive front calipers on rear with cutom axle build. :whistle:
options are endless on this one looks like. :thumb:
Is there enough room to machine it out for 4 inch tubes? Sure would make it easy to do 40 spline on a dana 80.
Do you have plans to offer these for 4 inch tubes or would I have to buy them and have them machined out?
