D60 Full Hydro Steer Arms, Billet Steel Raised
NorthWestFab
Canada Eh.
Our Latest D60 Full-Hydro Steer Arms
Same Great Features As Our Crossover Arms:
- 100% CNC Machined From 1810 Billet Steel Stock.
- Can Be Mounted Forwards or Reverse for Ram Flexibility
- Kingpin Pre-load Adjustment via 1" Set Screw
- Grease Zerk Fitting On Top For Ease Of Maintenance.
- Arm Geometry Adjusted For Steering and Kingpin Axis Inclination Angle.
- Tapered For Tie Rod Ends or Drilled For 3/4" Heims.
- 5th and 6th Hole for Aftermarket Reid Racing Knuckles.
- Compatable with our new Upper Kingpin System
With Some Added Features:
- Designed with cues from Sean 'Station' @ Performance Offroad Steering To give the best ackerman angle possible.
- Long enough to handle the proper length 8" DE ram for a D60 for maximum leverage.
- 1 1/4" Thick! [ not 1" like the rest of our competitors ]
We stock them blank, we can drill them for you at no extra cost! or ship them blank - it's up to you! (98% of the time the hole will be 8" From center for proper ram throw).
$ 269 Pair !
We also stock high strength chromoly installation studs ($29 / 4 studs and nuts)!
Give us a call to get yours ~ 250 248 6024.
Thanks.
If i order a set of these will I need to pay any taxes like if I shipped something to my customers in canada?
Do you sell the Kingpin Preload bolt and nut seperately? I have an old crossover setup with steering arms and have started to develop a little death wobble. I was going to do the washer trick until I saw these. I was hoping to retrofit my old arms (I have access to a machine shop and can drill/tap my existing arms).
I guess I could use a 1" fine thread bolt/nut and drill and tap for a grease fitting, but the head on yours would be much easier to deal with and would rather send the money your way.
Thanks,
Chris
Thanks,
Chris
PM Sent
