shaun89
so im about to install my D60 gears, i have no original carrier or shims, only the original pinion shims, but my question is about the carrier shims, i no u have to move it left to right,but is there a certain width it should be? im concerned ill get good backlash and mesh but have too many shims? and have too much bearing preload once i torque the carrier caps down.is it possible? or have too few shims and the bearings r too close to sit in the races properly. is this an issue or are the shims too thin to matter much?
