d60 hub studs - 1/2" to 9/16"
obijuank5
1 ton status
Solutions
Central Texas
I have a pair of 93 dodge single wheel dana 60 wheel hubs. If I drill out the stud holes and use gm studs, should I buy new gm rotors or dodge rotors? internet lore says they are different. Searching dana 60 hub brings up 1.21 jiggawatts of results. For clarity, what is the drill size for gm studs?
thanks
GM rotors are thicker than Dodge, and stud size. Thickness isn't gonna effect anything. I drilled out hubs once, but have no clue what size bit I used....They have to be pressed in obviously, and want interference fit.
That is high tech right there. Thank you.
.629" is a 16mm or 5/8" drill bit by some Internet charts they are interchangeable.
The only thing I remember was replacing 64 9/16"studs and 64 of the bigger nuts wasn't cheap....Close to $200 if I remember back from 2002.
