onetonjimmy
Registered Member
So I picked up a military cucv in may. I fixed a couple of things so it would be drivable, including new tires. I started noticing they showed lots of wear considering I only put about 3k miles on them. I also noticed the tires were tilted in at the top of the tire, and I could feel quite a bit of clunking on hard turns. This truck had less than 20k miles since new (1985), so I figured I take it apart and have a look- holy moly! king pin bushing cracked in half, but the king pin itself was barely screwed into the axle c. I literally turned it like two turns with my fingers, and out it came. What's weird is, there was no death wobble, vibrations and only a little pulling to one side. The threads were all good, and everything bolted back together with new parts. These things are supposed to be torqued to 5-600 ftlbs, so how in the world did they get so loose? Bad assembly line install?
