So I'm getting ready to rebuild a d60 to go into my truck. It was from a CUCV, so it's probably 30 years old, but with few miles.
I'm running a 4" and 35's but will be going to 37's when I swap, along w/ possibly an ez inch or something along those lines - if needed.
Not going to hammer this truck on major rocks and will be doing a bit of street driving, as it's a ways from my house to any offroad areas. Just want to build so that I don't have to fix stuff more than once - although I am not afraid of regular maintenance.
Going to do crossover steering, and don't want to buy arms more than once. I know at 37's you can start to run into problems w/ dw and I want to avoid that.
In this application, would the stock setup (nylon/spring) be appropriate?
Or, would bronze be better, and does anyone make some that don't require the tension- preload type arms?
The bronze bushing replacements I've seen state that they're meant for 'offroad only'. Is that because of some legal reasons, or because of the extra maintenance from needing to keep after the preload? Or some other reason?
How many of you have run bronze on the street for any length of time and what's your experience with them?
I've done some searching and guess I haven't found exactly what I'm looking for.
Josh
Josh
