Found out last time I took my blazer out that I broke off one of the leaf springs studs on the passenger side that go into the housing. What sucks about how mine broke off is it's virtually flush with the housing (actually somewhat down inside the housing). I've tried to weld a bolt to it to try and back it out, but that's not working (because of how it broke off). I started to try and drill it out, but what drill bits are you using? Cause the ones I have don't want to cut into it very well.
Anyone had this before and if so what worked for you to get it out. I already have another set of new studs to bolt everything back up, I just need to get the old broken one out.
Thanks!
Thanks!
