lookin for some front 60 outer axle shafts. can be good or broken, must have good ears.
Are you using them to make a driveshaft? I have a outer and inner but using the other outer and inner to make my shaft.
yea thats the plan. any way you could cut down the inner to save weight for shipping? how much do you want for them? thanks
Yes I can cut them. Do you need a flange made too?
im going to be bolting it to the front of my 205, which is 32spline output (im lookin for a cv flange right now, so the driveshaft flange can bolt up to it) what kind of magic can you work?
that would be awesomeim going to be bolting it to the front of my 205, which is 32spline output (im lookin for a cv flange right now, so the driveshaft flange can bolt up to it) what kind of magic can you work?
I don't have a 32 spline front 205 flange. I have a 30 spline one. I will have to check on getting the driveshaft flange made. Only problem is I need to make sure the 205 flange has the same dimentions as the 30 spline GM flange. There will be a few day lead time on getting the driveshaft flange machined once I have the dimentions.
im in no rush, i wont be able to really mess with everything until beginning of june anyways, i just want to collect as much of the parts i need now to keep down lag time waiting for parts when i am able to work on it. what dimensions for the 32spline flange do you need? just the hole spacing, and pilot size? i can search around, im sure i can find the info on pirate.that would be awesomeim in no rush, i wont be able to really mess with everything until beginning of june anyways, i just want to collect as much of the parts i need now to keep down lag time waiting for parts when i am able to work on it. what dimensions for the 32spline flange do you need? just the hole spacing, and pilot size? i can search around, im sure i can find the info on pirate.
Let me know what you find out and we will go from there.
