I've got four (so far)
1. Is there any reason I can't ditch the little sheet metal do-hickeys on the outside of the caliper bracket? Mine are toast.
2. Any tips on removing the lower kingpin? Mine is tuck on real good.
3. My tie rod ends have different threads where they pass through the knuckle. One is 5/8" and one is 9/16". I assume the larger one was bored out at some point. I am not planning on going to high steer. Any issues with that?
4. There are these plastic wedges between the knuckle and spindle. I assume they are for camber adjustment??? Do I need to keep/replace them?
TIA
TIA
BTW man, I'm hoping to finish setting up the ARB on mine today!
