I am finally going to start rebuilding my D60 so I can finally sling it under the front of my truck (hopefully before the end of the year
Here is what I have come up with for the parts I will need:
4.88 gears
Master R&P install kit
Wheel bearings
kingpin rebuild kit
calipers
discs
axle u-joints
axle seals
Edit:
Hub seal
Spindle bearings
Brake Pads
Pics
What else should I rebuild or replace while I have it apart? I am going to hold off on a locker, 35 spline outers, and new hubs 'till I win the lottery.
)Here is what I have come up with for the parts I will need:
4.88 gears
Wheel bearings
kingpin rebuild kit
calipers
discs
axle u-joints
axle seals
Edit:
Hub seal
Spindle bearings
Brake Pads
Pics
