RGV72BLAZER
- Joined
- Jan 23, 2006
- Posts
- 2,444
- Reaction score
- 68
Selling my installed but never used (other than rolling the Blazer around the shop) Sky MFG HiSteer kit. Complete from the two high steer arms, tie rod, drag link, TREs, and pitman arm. Also included are the 8 ARP studs with nuts that I got from OffRoad Design. The 2WD steering box will also go with it with the top cap tapped for hydro assist. Finally, the XJ shaft to get rid of your lousy rag joint stock shaft will be included. All this for a Chevy 60. I had the kit ordered for 5-7" of lift, but you'd probably just need to fab up something for the drag link. Like I said everything is pretty much new because I've used it move the Blazer around inside the shop. The only thing I bought used was the steering box. Selling to upgrade knuckles and get another set of steering arms to run full hydro. $850 shipped. Post or PM. Located in Harlingen, TX. Thanks.
